Increase acquiring rate of Agilent 34401A multimeter
Hello.
My name is José Restolho and I'm a researcher in Portugal. I've an Agilente 34401A multimeter and I'm controlling it by serial. The problem is that it only acquires a point each 1.5 s which is to much. I need that it acquires with a rate of 100 ms at least.
Can someone help me?
Thank you.
Best regards José Restolho
(3,658 Views)
Accepted by Restolho
You need to first move the initialization, configure, and close to outside the loop. You'll probably also need to place the file write in a different loop and pass it data via a queue such as in the producer/consumer architecture (see examples and File>New...). The instrument also can do a multiple point acquisition. Lastly, you might need to use something a bit faster than a serial connection such as USB, Ethernet, or GPIB (whatever the instrument has besides serial).
(3,644 Views)
Dear Dennis Knutson.
Thank so much for your answer. It saved my day.
José Restolho
(3,638 Views)
