04-04-2008 07:24 AM
Uninstalling NI-KAL (nikal): doneI have attached the niSystemReport.out.gz to this message.
/bin/rm -rf objects
Updating NI-KAL:
NI-KAL update failed.
/bin/cp nikal.c objects/nikal.c
/bin/cp nikal.h objects/nikal.h
make -C /lib/modules/2.6.22-14-generic/build SUBDIRS=/usr/local/natinst/nikal/src/objects modules
make[1]: Entering directory `/usr/src/linux-headers-2.6.22-14-generic'
CC [M] /usr/local/natinst/nikal/src/objects/nikal.o
/usr/local/natinst/nikal/src/objects/nikal.c: In function 'nNIKAL100_buildControlURB':
/usr/local/natinst/nikal/src/objects/nikal.c:3422: warning: passing argument 7 of 'usb_fill_control_urb' from incompatible pointer type
/usr/local/natinst/nikal/src/objects/nikal.c: In function 'nNIKAL100_buildBulkURB':
/usr/local/natinst/nikal/src/objects/nikal.c:3447: warning: passing argument 6 of 'usb_fill_bulk_urb' from incompatible pointer type
/usr/local/natinst/nikal/src/objects/nikal.c: In function 'nNIKAL100_buildInterruptURB':
/usr/local/natinst/nikal/src/objects/nikal.c:3498: warning: assignment from incompatible pointer type
/usr/local/natinst/nikal/src/objects/nikal.c: In function 'nNIKAL100_buildIsochronousURB':
/usr/local/natinst/nikal/src/objects/nikal.c:3539: warning: assignment from incompatible pointer type
/usr/local/natinst/nikal/src/objects/nikal.c:3644:48: error: macro "INIT_WORK" passed 3 arguments, but takes just 2
/usr/local/natinst/nikal/src/objects/nikal.c: In function 'nNIKAL100_usbClearHaltAsync':
/usr/local/natinst/nikal/src/objects/nikal.c:3643: error: 'INIT_WORK' undeclared (first use in this function)
/usr/local/natinst/nikal/src/objects/nikal.c:3643: error: (Each undeclared identifier is reported only once
/usr/local/natinst/nikal/src/objects/nikal.c:3643: error: for each function it appears in.)
/usr/local/natinst/nikal/src/objects/nikal.c: In function 'nNIKAL100_reserveInterrupt':
/usr/local/natinst/nikal/src/objects/nikal.c:3946: warning: 'deprecated_irq_flag' is deprecated (declared at include/linux/interrupt.h:66)
/usr/local/natinst/nikal/src/objects/nikal.c:3946: warning: passing argument 2 of 'request_irq' from incompatible pointer type
make[2]: *** [/usr/local/natinst/nikal/src/objects/nikal.o] Error 1
make[1]: *** [_module_/usr/local/natinst/nikal/src/objects] Error 2
make[1]: Leaving directory `/usr/src/linux-headers-2.6.22-14-generic'
make: *** [objects/nikal.ko] Error 2
ERROR: make of nikal kernel module failed, not installing kernel module.
updateNIDrivers should be called again after fixing the problem.
Logging failure...
Include the file /tmp/niSystemReport.out.gz when contacting
National Instruments for support
04-05-2008 08:48 AM
04-07-2008 03:12 AM
04-07-2008 08:58 AM
04-07-2008 10:54 AM
04-07-2008 11:46 AM
04-08-2008 05:13 AM
04-08-2008 08:28 AM
04-09-2008 03:17 AM
