NI-DAQmx on Red Hat Enterprise Linux 5
I am not able to install NI-DAQmx on my Red Hat Enterprise Linux machine. I know that NI doesn't fully support RHEL WS 5 for NI-DAQmx but does for NI-DAQmx base. However, NI-DAQmx Base is not acceptable for us to use. Has anyone been able to install it? I've tried the tutorial on here for Fedora Core 6 assuming it should be the same, but did not have any success.
(3,619 Views)
Hello Mahill,
In lieu of someone posting back with instructions on how to do this the best suggestion I can give you is to try the NI-DAQmx 8.0 for  RHEL WS 3 on your machine.  If that doesn't work for you then I think the easiest solution would be to downgrade your operating system to RHEL WS 3 in order to use the driver.  It may be possible to install a version of NI-DAQmx on RHEL WS 3, but as you mentioned, this is not officially supported and so I don't have a way to test or advise you on how to do it.  If downgrading to RHEL WS 3 is not an option we'll need to rely on someone else from the forum community to provide a solution.
Also, another consideration when using version 8.0 of NI-DAQmx is that you'll need either LabVIEW 7.0, 7.1, or 8.0 as given in this KnowlegeBase: NI-DAQ & LabVIEW Version Compatibility (for Windows).
I know this isn't exactly what you're looking for, but hopefully it gives you another option if nobody is able to advise you on the installation you're looking for.
Have a great day!
Brooks
(3,587 Views)
