04-07-2008 09:02 AM
04-08-2008 11:47 AM
Hello Mahill,
In lieu of someone posting back with instructions on how to do this the best suggestion I can give you is to try the NI-DAQmx 8.0 for RHEL WS 3 on your machine. If that doesn't work for you then I think the easiest solution would be to downgrade your operating system to RHEL WS 3 in order to use the driver. It may be possible to install a version of NI-DAQmx on RHEL WS 3, but as you mentioned, this is not officially supported and so I don't have a way to test or advise you on how to do it. If downgrading to RHEL WS 3 is not an option we'll need to rely on someone else from the forum community to provide a solution.
Also, another consideration when using version 8.0 of NI-DAQmx is that you'll need either LabVIEW 7.0, 7.1, or 8.0 as given in this KnowlegeBase: NI-DAQ & LabVIEW Version Compatibility (for Windows).
I know this isn't exactly what you're looking for, but hopefully it gives you another option if nobody is able to advise you on the installation you're looking for.
Have a great day!
