Is it enough to have serial config in main vi or??
From your last image, I don't thing you want that last semicolong (;) in your write command.  I think that will interrupt your querry in the instrument.
Message 11 of 14
(2,591 Views)
It was already there.I did not add it.
I thought of using the complete serial part of 34401 in my code.Hoping it works.
Message 12 of 14
(2,588 Views)
As mentioned,i am using the serial comm part of 34401 here.Kindly help for the error highlighted in the pic.
Message 13 of 14
(2,575 Views)
Please ignore my previous question as i found a solution for that.
I have 2questions  now,In the PIC attached,
1.Before the Queary ID,the instrument must be set to REmote Mode,though it passes trough without error,sttill the instrument is not set to REMOTE.Let me know where i am going wrong here.
2.Why is the Query ID always fails even after making the required changes for serial comm.
Please guide on high prio.Your inputs are badly required for me to progress.
Message 14 of 14
(2,559 Views)
