Is there a Labview driver for a Teac GX-1 data recorder via a SCSI card?
I'd like to be able to use Labview to communicate to a Teac GX-1 data recorder via an Adaptec 1480 SCSI PCMCIA card. Can anyone help me? Thanks.
(3,270 Views)
I would assume that because the connection type is SCSI, it would either end up looking like another drive to windows (in which case you can just use the standard write to HD functions), or it will come with some API which you will have to use CIN's or something of that nature to control.
Hope this helps out.
Best Regards,
Aaron K.
Application Engineer
(3,270 Views)
