Showing results forĀ
Search instead forĀ
Did you mean:Ā
Lab::VISA installation using Windows 7
I am trying to install Lab::Visa using strawberry perl and I get the following error. What am I doing wrong? I am a novice to perl and Visa module.  Any help is greatly appreciated.
I tried following the instructctions from the link here, however the path to visa32.lib seems to be correct in my Makfile.PL.
http://search.cpan.org/dist/Lab-VISA/lib/Lab/VISA/Installation.pod
C:\Strawberry\cpan\build\Lab-VISA-3.02-T3pLOd>dmake
Skip blib\lib\Lab\VISA.pm (unchanged)
Skip blib\lib\Lab\VISA\Installation.pod (unchanged)
Skip blib\lib\Lab\VISA.pod (unchanged)
Running Mkbootstrap for Lab::VISA ()
"C:\Strawberry\perl\bin\perl.exe" -MExtUtils::Command -e chmod -- 644 "VISA.bs"
gcc -c "-IC:\Program Files (x86)\IVI Foundation\VISA\WinNT\include" -s -O2 -DWIN32 -DWIN64 -DCONSERVATIVE -DPERL_TEXTMODE_SCRIPTS -DPERL_IMPLICIT_CONTEXT -DPERL_IMPLICIT_SYS -f
wrapv -fno-strict-aliasing -mms-bitfields -s -O2 -DVERSION=\"3.02\" -DXS_VERSION=\"3.02\" "-IC:\STRAWB~1\perl\lib\CORE" visa_wrap.c
dlltool --def VISA.def --output-exp dll.exp
g++ -o blib\arch\auto\Lab\VISA\VISA.xs.dll -Wl,--base-file -Wl,dll.base -mdll -s -L"C:\STRAWB~1\perl\lib\CORE" -L"C:\STRAWB~1\c\lib" visa_wrap.o "C:\STRAWB~1\perl\lib\CORE\libper
l522.a" "C:\Program Files (x86)\IVI Foundation\VISA\WinNT\lib\msc\visa32.lib" "C:\STRAWB~1\c\x86_64-w64-mingw32\lib\libmoldname.a" "C:\STRAWB~1\c\x86_64-w64-mingw32\lib\libkernel32
.a" "C:\STRAWB~1\c\x86_64-w64-mingw32\lib\libuser32.a" "C:\STRAWB~1\c\x86_64-w64-mingw32\lib\libgdi32.a" "C:\STRAWB~1\c\x86_64-w64-mingw32\lib\libwinspool.a" "C:\STRAWB~1\c\x86_64-
w64-mingw32\lib\libcomdlg32.a" "C:\STRAWB~1\c\x86_64-w64-mingw32\lib\libadvapi32.a" "C:\STRAWB~1\c\x86_64-w64-mingw32\lib\libshell32.a" "C:\STRAWB~1\c\x86_64-w64-mingw32\lib\libole
32.a" "C:\STRAWB~1\c\x86_64-w64-mingw32\lib\liboleaut32.a" "C:\STRAWB~1\c\x86_64-w64-mingw32\lib\libnetapi32.a" "C:\STRAWB~1\c\x86_64-w64-mingw32\lib\libuuid.a" "C:\STRAWB~1\c\x86_
64-w64-mingw32\lib\libws2_32.a" "C:\STRAWB~1\c\x86_64-w64-mingw32\lib\libmpr.a" "C:\STRAWB~1\c\x86_64-w64-mingw32\lib\libwinmm.a" "C:\STRAWB~1\c\x86_64-w64-mingw32\lib\libversion.a
" "C:\STRAWB~1\c\x86_64-w64-mingw32\lib\libodbc32.a" "C:\STRAWB~1\c\x86_64-w64-mingw32\lib\libodbccp32.a" "C:\STRAWB~1\c\x86_64-w64-mingw32\lib\libcomctl32.a" dll.exp
visa_wrap.o:visa_wrap.c:(.text+0xb7d): undefined reference to `viClose'
visa_wrap.o:visa_wrap.c:(.text+0xcbd): undefined reference to `viClear'
visa_wrap.o:visa_wrap.c:(.text+0xde6): undefined reference to `viOpenDefaultRM'
visa_wrap.o:visa_wrap.c:(.text+0xf98): undefined reference to `viSetAttribute'
visa_wrap.o:visa_wrap.c:(.text+0x11c4): undefined reference to `viGetAttribute'
visa_wrap.o:visa_wrap.c:(.text+0x1430): undefined reference to `viGpibControlREN'
visa_wrap.o:visa_wrap.c:(.text+0x17b2): undefined reference to `viReadSTB'
visa_wrap.o:visa_wrap.c:(.text+0x197a): undefined reference to `viFindNext'
visa_wrap.o:visa_wrap.c:(.text+0x1b9f): undefined reference to `viWrite'
visa_wrap.o:visa_wrap.c:(.text+0x1e7b): undefined reference to `viOpen'
visa_wrap.o:visa_wrap.c:(.text+0x216c): undefined reference to `viRead'
visa_wrap.o:visa_wrap.c:(.text+0x23f4): undefined reference to `viFindRsrc'
collect2.exe: error: ld returned 1 exit status
dmake: Error code 129, while making 'blib\arch\auto\Lab\VISA\VISA.xs.dll'
(5,591 Views)
I moved your post from the LabVIEW board bit I'm not sure your post belongs anywhere on the NI forums. This Lab::VISA is not an NI program and is no way supported by NI. The same is true of your strawberry Perl. The only thing that would be supported is an installation of NI-VISA and you haven't even mentioned what version of that you installed. The versions listed on that link are pretty old.
(5,572 Views)
I am using NI-VISA 15.0.1. I am trying to get this perl module installed http://search.cpan.org/~akhuettel/Lab-VISA/lib/Lab/VISA/Installation.pod but I always get this unreferenced error.
(5,478 Views)
Contact whoever wrote this LAB::VISA. Send pretty pointless making references to errors generated by some odd third party developers.
(5,475 Views)
