Labview AD5933
Hi again, I hope you don´t mind answer another question.
Is there any trick to use a 32 bits dll in LV 64bits?
Thanks again,
Breno
Message 11 of 12
(2,358 Views)
Hi Breno,
Did you find a resolution to your problem?  I'm doing the same thing, using LabView with an AD Eval Board and I'm stuck right where you were.  I'd appreciate the help.
Message 12 of 12
(1,169 Views)
