Motor Control Using MAX/Motion Assistant
No, it just says the move was successful... even though it didn't move.
Should I have the microstepping on a certain setting?
Greg-H wrote:
First set all of the limit switches and home switch to active low, so that they are not showing up in as tripped in MAX.  When the motor does not move with these settings are you seeing an error of any sort?
Greg H.
Message 11 of 12
(1,304 Views)
How many steps are you telling it to move?
Greg H.
Message 12 of 12
(1,301 Views)
