11-22-2005 04:29 PM - edited 11-22-2005 04:29 PM
Message Edited by j_chandler on 11-22-2005 04:33 PM
11-23-2005 08:26 AM
Is it possible for you to post a MAX system report? You can create this report in MAX by going to Help >> System Information, and clicking on the "Report..." button at the bottom of the window that opens up. Take note of where the nireport.txt is getting saved to, so that you can post it here. This should give us all the information about your drivers that we could hope for.
Also, even though the GPIB-USB-HS does not show up in MAX, does it show up in Windows Device Manager? Does it appear to be installed correctly, or is there a yellow exclamation mark on it? Or does it not show up at all?
Logan S.
11-28-2005 02:10 PM
