08-14-2007 02:45 PM
08-15-2007 11:43 AM
Hello Oley,
Yes, the new version of NI-MAX that came out with NI-FieldPoint 6.0 is NI-MAX 4.3. You should be able to install this newer version from the driver CD that included NI-FieldPoint 6.0.
Clint M
08-15-2007 11:47 AM
08-16-2007 09:08 AM
08-16-2007 10:11 AM
08-16-2007 10:31 AM
Kalin Taskov sent it to me via ftp. The zip file was located as follows: ftp://ftp.ni.com/outgoing/marko.zip
I installed it that way and am still having some issues. After installing Fieldpoint 4.3 (got it through Serial 3.3), it does not display any Data Neighborhood, Devices and Interfaces, Historical Data, Scales, Software, IVI Drivers, nor Remote Systems icons in the left pane.
Also, I previously had a Fieldpoint listing under the Tools menu before, where I could Save and Save As Fieldpoint configurations. Not yet under 4.3.
I'm going to wipe my PC and try from the beginning. Try an install of Serial 3.3 (thus including MAX 4.3, then install Fieldpoint 6.0) and see if i can find my FP-1601.
Hope this helps! Thanks!
-Mark
08-16-2007 01:23 PM
08-16-2007 01:29 PM
08-16-2007 01:31 PM
08-16-2007 01:34 PM
Will try.
Thanks!
-Mark
