NI MAX crash on exit
Did you ever figure out what this was? I am setting up a new system (Windows 10 Enterprise with advanced group policy options enabled) and I am getting this crash upon exit. As you mentioned, it doesn't seem to be causing problems but it would be nice to make it go away. As far as I can tell I don't have any firewall settings enabled on this machine (no network connections).
Message 11 of 12
(772 Views)
From the services manager
Try changing the setting for startup type from automatic to "Automatic, delayed start"
I've worked in a few environments where security policies provided by the client caused a conflict with services that start in the wrong order.  I am not an IT Pro and can't explain why.  But, as a Troubleshooting exercise I have played with the Delayed Start option of several NI services with some success.
Message 12 of 12
(770 Views)
