‎10-29-2016 08:26 PM
I'm probably in the wrong forum but didn't know where to start. I'm very new to all of this, but want to learn - this will probably be very easy to most of you. I have a 2 wire electromagent and want to write a program to turn on and off. What hardware do I need?
‎10-30-2016 03:06 PM
‎10-30-2016 07:11 PM
Great this may be too much for me - I've played around with the program and feel that I could I could get a simple program written, but I'm not familiar at all with any of the hardware. I was hoping just the magnet and somehting to plug into would be it. This is the magnet description:
55LB 25kg Electric LIfting Magnet Electromagnet Solenoid Lift Holding 40mm
Would I need a relay or amplifier for something like this?
Thanks for your help!
‎10-31-2016 04:05 AM
so you only need to switch this on and off.
You can use a 12 volt power supply and make sure it can handle 8 watt so almost 1 amp.
Be sure to add a diode over the voltage to suppress high voltages when switching off.
A coil (as is in the magnet) willtry to keep the current going when switching off and can generate very high voltages.
You can use a relay and a usb to digital io cable to connect the power to the magnet.
Start with a real switch and makeit work and then find a usb to digital IO device that can be controlled by the pc. LabVIEW can do this but is aybe overkill for you.
‎10-31-2016 07:46 AM
This is great information - thank you so much. I agree this would be overkill with LabView, but I'm actually adding this function to a much larger program. I have already written a program utilizing an acclerometer that reads the force exerted on an object when dropped onto playing surfaces. I would like to use the magnet to drop the object and trigger the start of data collection for the accelerometer. I had not idea about the high voltage generated when the magnet switches off - this could have caused interference with gathering the voltage data from the accelerometer.
