 Javernz
			Javernz
			07-27-2012 06:00 AM
Dear Sir/Mdm,
I'd just reformat my company laptop than install the NI software. When the installation complete, I plug in the PCMCIA-GPIB card into the slot. It able to be detected but it show problem(as show in attach file)
I'd re-try to install the software(ver. 4.6.2f1) several time and even install the software of lower version(ver. 4.5). The problem still remain.
I even try to change to other PCMCIA-GPIB card but the problem still remain.
Hope you could advise the root cause of it.
 nyc_(is_out_of_
			nyc_(is_out_of_07-27-2012 08:15 AM
@Javernz wrote:
Dear Sir/Mdm,
When you "reformat" your computer you are wiping out your computer's hard drive.
Perhaps you meant you re-installed Windows. If so, with many computers, after re-installing Windows, you need to install other base drivers. I know this is true for Dell. One of these base drivers is the PCMCIA driver.
07-29-2012 08:44 PM
Dear Sir/Mdm,
Yes, it meant that I'd re-install my window for my company laptop(Dell E6400).
If I need to install other base driver and for Dell, one of the base driver is PCMCIA driver. Wasn't it been install during the installation process when I install the NI software which start to puzzle me. I even try update the driver with NI installation CD. The result is show in the attach file.
I even try using GPIB-USB-HS device instead of PCMCIA card, the problem still occur. I thought USB is a plug and play device which don't need to install any driver.
Hope to clarify my doubt.
 nyc_(is_out_of_
			nyc_(is_out_of_07-30-2012 08:18 AM
08-02-2012 09:21 PM
Dear Sir/Mdm,
Thank for the support.
But currently I can't determine the problem was it lay at the base driver. Therefore, I currently seek for our IT to support on this case.
If the problem can't be solve internally, than I might feedback again.
Thank,
