PXIe-8510/6
Where to find the pinning for LIN PXIe-8510/6.
(3,997 Views)
For PXIe-8510, you need an XNET Transceiver cable to use the port in CAN or LIN mode.
https://www.ni.com/en-us/shop/hardware/products/transceiver-cable.html
Since you mentioned LIN, I assume the cable is going to be TRC-8546 and referring the below manual,
https://www.ni.com/pdf/manuals/374536e.pdf
Santhosh
Soliton Technologies
(3,950 Views)
thank you Santo, but there is no information here on which contact the LIN is connected to.
(3,936 Views)
I believe this is what you're looking for, LIN is connected to Pin7 on DB9 connector.
Santhosh
(3,927 Views)
Super! Thank You😁
(3,922 Views)
