Problem while configuring NAT 7210 as active controller
     I am developing a board with 7210 and microcontroller.
I configured the 7210 as an active controller and got CIC bit set and ATN and IFC asserted.
But i am unable to get CO bit set. When will be CO bit set actually?
I also have the doubt about DAV* pin. I am writing data to CDOR and cud see the same on the output DIO pins. But still the DAV* pin low. When the handshaking actually takes place??
Please help me.. It is very urgent .. I have to submit the project within 3 days..
Please try to help me
thanking you ,
swathi
(3,373 Views)
Duplicate post...question is being addressed here:
http://forums.ni.com/ni/board/message?board.id=140&message.id=26692
(3,355 Views)
