03-14-2007 04:23 PM
03-14-2007 04:49 PM
03-14-2007 04:51 PM
I don't know what you mean by 'find it'. How are you trying to find a serial instrument? Since you can communicate to a different instrument, I would assume that your com port is listed. You can try using MAX to communicate to the scope or just try using Hyperterminal. Serial control of an instrument is not the easiest thing to get going. You may have incorrect com settings (baud rate, parity, etc) or even the wrong type of cable. I'm not familiar with that scope but it is possibleI always verify that the port is set according to the manual and always use Hyperterminal first.
Also, in the future, if you get an error message, in your post you should include the error code that you get. That's vital information in helping to solve problems.
03-15-2007 11:16 AM
03-16-2007 03:40 PM
