SCSI-68 to 8 DB9 null modem
Up to now, I use 8 null modem at the end of my standart cable to be able to communicate with my devices.
I'm looking for a SCSI-68 to 8 DB9 null modem cable (RS232 and RS485 as well). Somebody knows if NI do this kind of cable ? Where I can find it ?
Thx
(4,550 Views)
What does the SCSI end plut into? Is this some custom multi-port com board? If it's a commercial board, the vendor should be able to provide a cable. I have some 8 port cards that use an 80 pin connector at one end and break it out into 8 DB25s. This type of cable is very custom and I seriously doubt that you will find something off the shelf. There just doesn't exist a standard for a SCSI-68 cable used for multiple serial ports.
(4,541 Views)
Doyon,
It looks like we might actually have a few cables that have those connectors.  Check out the Developer Zone article here and scroll down to the bottom to see a list of NI's serial cables.  If you'd like, I could have someone work up a quote for you for a few of those cables.
Chad B. » National Instruments » ni.com
(4,528 Views)
CHad B,
5. RS-232 SCSI-68 to 8-port 9-pin male D-Sub
    185196-01 (1 meter) for 8 port PCI/PXI-232 cards*
    * This is only a convertor cable/box to male DB9 connector. You also need one RS-232 or RS-485 null-modem cable per port, as shown above.
    Am I stuck to have 8 null-modem ?
    (4,524 Views)
    Hey Doyon,
    I was curious if we could clarify what you're looking for?
    On the SCSI end, are you looking for a SCSI connector like the one seen in connector 5 or 6 of the link the Chad had posted?
    For the DB9 connector, Are you looking for a connector similar to that in Figure 5 or 6?
    What exactly do you mean by "You also need one RS-232 or RS-485 null-modem cable per port"
    Nick D.
    (4,502 Views)
    I apologize for misunderstanding you the first time.  That cable is essentially designed to be convertor, not an end-to-end cable, so it's terminated with male ends instead of female ends; however, you could just pick up a bunch of gender changing adapters if you're trying to reduce cable clutter.
    (4,485 Views)
