Safely Remove GPIB-USB-HS Devices
I have several GPIB instruments connected to PC through GPIB-USB-HS. I know normaly for USB devices I need to do the safe removal. What should I do in this case to remove connections while everything is powered on.
Fliu
(5,290 Views)
Accepted by FLiu
I try to always power down an instrument before disconnecting it.
(5,266 Views)
Thank you for your reply.
(5,240 Views)
