02-24-2009 10:13 AM
I am a newbie at TCL programming. I wish to automate test cases for a Rhode and Schwarz FSL. As of now I can send individual SCPI commands using the NI-VISA sessions.
I need to now write TCL scripts which can pass the SCPI commands to the FSL.
Please help me how to go about doing this. Any sort of help/advice will be great 🙂
Rohit
02-25-2009 02:33 AM
Hi Rohit,
the only thing I can offer you are VXIPnP Instrument Driver which are using VISA for programming in C/C++/etc, but using TCL is from my point of view quite rar.
Regards Juergen
02-26-2009 07:55 AM
i used the following code from the visa manual
#include "visa.h"
#define MAX_CNT 200
int main(void)
ViStatus status; /* For checking errors */
ViSession defaultRM, instr; /* Communication channels */
ViUInt32 retCount; /* Return count from string I/O */
ViChar buffer[MAX_CNT]; /* Buffer for string I/O */
/* Begin by initializing the system*/
status = viOpenDefaultRM(&defaultRM);
if (status < VI_SUCCESS) {
/* Error Initializing VISA...exiting*/
return -1;
/* Open communication with GPIB Device at Primary Addr 1*/
/* NOTE: For simplicity, we will not show error checking*/
status = viOpen(defaultRM, "GPIB0::1::INSTR", VI_NULL, VI_NULL,
&instr);
/* Set the timeout for message-based communication*/
status = viSetAttribute(instr, VI_ATTR_TMO_VALUE, 5000);
/* Ask the device for identification */
status = viWrite(instr, "*IDN?\n", 6, &retCount);
status = viRead(instr, buffer, MAX_CNT, &retCount);
/* Your code should process the data */
/* Close down the system */
status = viClose(instr);
status = viClose(defaultRM);
return 0;
I have added the header files from the include folder in the VXIPNP folder, still on compiling it in Dev c++ it gives me linker error when i execute it as a C source. When i execute it as a C++ code i get "invalid conversion from `const char*' to `ViByte*' " on line 22.
What should i do. Is there any other compiler i should use?
02-26-2009 09:36 AM
please download the RsSpecAn VXIPnP driver and the Read Trace Example and have a look into the source code. (http://www2.rohde-schwarz.com/product/FSL.html)
your posted problem exists a simple solution (as referring to the example):
#include <visa.h>
#include "rsspecan.h"
/* initialize driver */ //implies opening a visa session
rsspecan_init (instr_desc, id, reset, &instrSession)
hope that helps?
regards juergen
04-22-2009 08:08 AM
hi Rohit
If your device has a serial port or Ethernet port you can simply do this in Tcl
#For a socket do set sd [ socket <ip> <port>
#fconfigure $sd -blocking 0
set fd [ open com1 RDWR]
fconfigure $fd -mode 9600,n,8,1 -blocking 0
puts $fd "*IDN?
flush $fd
puts [read $fd]
etc..
For GPIB ports only get an NI card or USB to GPIB device.
Install the GPIB-tcl package
Then read the GPIB-tcl docs.
Controlling SCPI based devices wtih TCL is trivial, probably the same with a lot of scripting languages, no need to compile code to talk to instruments,thats just crass!
Derek
