Serial Communication to Heidenhain ND 281 B
The Heidenhain ND 281 B will output it's display ( from linear encoder) to my pc using Windows Hyper Terminal when I send Cntrl B. I cannot input Cntrl B into the send string on my LabVIEW example VI's. For my application I need LabVIEW to send and receive this between 100 and 1000 times per second, and use the data returned as a plot axis vs. time; and as a plot axis vs. an analog input signal (strain gauge force cell). Duplicate digital readout, also. Additionally, I need the point in time where the strain signal and serial signal occur not to be distorted.
(4,396 Views)
Ctrl B is the STX character or hex02 and to enter it into a string control, right click and select '\' Codes Display and enter \02 or right click and select hex display and enter 02.
(4,395 Views)
Thanks Dennis, you da man....
(4,386 Views)
