The Serial Port give a 16408 error, i try all that the support page request
The system is composed by two serial 485 port that communicates, one with 8 devices, one with 3 devices. On port with 3 devices it run good, but in port with 8 devices it doesn't run! The speed and other options is OK. The system has runned until 2 days ago, when begin the trouble...I haven't change nothing ! I don't have any idea to shoot the problem. How i can solve ? Thanks
(3,775 Views)
Something must have change in one of the devices. The 16408 means that a serial break was detected and a framing error occurred.
You can find the meaning of this error number in the KB: What Do the Error Numbers Received from the Serial Port VIs Mean?. It actually uses this error code as a the example on how to interpret the error numbers.
Here are some KBs that mention this specific error.
Why Do I Get Errors 16400 and 16408 and How Do I Fix Them?
Receiving a 16408 Error when Using the Serial Port VIs
DiegoF
(3,775 Views)
mumble...i have tried to excange the two port, initially runs...but after some minutes it doesn't run !!! It can be caused by computer speed ? The two port share the same memory area...is normal ? Thanks...
P.S. Can you answer for tomorrow ???
(3,775 Views)
It is possible to have this error while labview run ? for example for 2 minutes run but after it breaks. What can send a break signal ?
(3,775 Views)
