Timing out on Serial Read
Yes, the "instrument" is a device we built in the lab and we are using this "USB245M" to virtualize a RS232 COM port to communicate with the PC.  Here is the documentation on the USB245M.  Unfortunately, it isn't very good.
http://www.ftdichip.com/Documents/DataSheets/DLP/dlp-usb245m13.pdf
Message 11 of 16
(2,018 Views)
That TXE# pin is set from the micro it looks like. That would point to a hardware problem or something wrong in the micro code.
Message 12 of 16
(2,009 Views)
We aren't controlling TXE# from the microcontroller and are able to retrieve data in Matlab.  My understanding is that TXE# is controlled by the USB245M, I just was wondering if I also had to enable it initially from the PC.  I'm starting to think that isn't actually my problem.
Message 13 of 16
(2,004 Views)
Accepted by topic author was1984
Can you read data in Hyperterminal?
Message 14 of 16
(1,999 Views)
Ok, I spoke with the person who wrote the matlab code and have this figured out.  There is a required transmit byte before data starts transmitting.  Thanks for your help with this.
Message 15 of 16
(1,985 Views)
If I ever make a signature, that'll be it.
Richard
Message 16 of 16
(1,981 Views)
