Transfer an image through serial port from PC to PC
Need the VI that runs on the other pc as well as the make and model of the instrument connected there. If you are using the run continuous button, stop using it and use a while loop with an event structure.
Message 21 of 22
(909 Views)
Yes Joja,
As Dennis noted, we'll need that information. Have you used Measurement and Automation Explorer (MAX) before? Can you see the device connecting the two computers on MAX at all, or even in Windows Device Manager? This article may help. If so, does a self-test or test panel in MAX communicate?
Deborah Y.
Deborah Burke
NI Hardware and Drivers Product Manager
Certified LabVIEW Architect
Message 22 of 22
(898 Views)
