Unable to change transceiver mode (4 wire to 2 wire) for USB 485 serial port
I am trying to setup a USB-RS485 device as per this knowledge base document:
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019MPySAM&l=en-US
However all of the Advanced options under the serial com port are grayed out and changing the transceiver mode from 4 wire to 2 wire is not possible. How can I enable these?
Thanks.
(4,864 Views)
Hi ah.bic,
Are you using a serial card or your machine's built in serial ports? Have you confirmed that these ports are configured correctly (IDN command, loopback test, etc)? Finally, what version of the NI-Serial drivers are you currently using? You should update to the latest NI-Serial drivers if you haven't already.
I hope this helps!
Andy C.
Applications Engineering
(4,835 Views)
Accepted by ah.bic
On Windows Vista and later, these settings can only be modified by running MAX as Administrator. Just right-click on the icon, and choose "Run as Administrator", and everything should be available to you.
(4,810 Views)
Andy, Jason,
The device is a National Instruments USB to RS485/422 interface cable (https://www.ni.com/en-us/shop/model/usb-485.html). Jason's solution of running NI MAX as admin provided access to the settings.
Many thanks.
Al
(4,798 Views)
