Unable to change transceiver mode (4 wire to 2 wire) for USB 485 serial port
I am trying to setup a USB-RS485 device as per this knowledge base document:
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019MPySAM&l=en-US
However all of the Advanced options under the serial com port are grayed out and changing the transceiver mode from 4 wire to 2 wire is not possible. How can I enable these?
Thanks.
(4,845 Views)
Hi ah.bic,
Are you using a serial card or your machine's built in serial ports? Have you confirmed that these ports are configured correctly (IDN command, loopback test, etc)? Finally, what version of the NI-Serial drivers are you currently using? You should update to the latest NI-Serial drivers if you haven't already.
I hope this helps!
Andy C.
Applications Engineering
(4,816 Views)
Accepted by topic author ah.bic
On Windows Vista and later, these settings can only be modified by running MAX as Administrator. Just right-click on the icon, and choose "Run as Administrator", and everything should be available to you.
(4,791 Views)
Andy, Jason,
The device is a National Instruments USB to RS485/422 interface cable (https://www.ni.com/en-us/shop/model/usb-485.html). Jason's solution of running NI MAX as admin provided access to the settings.
Many thanks.
Al
(4,779 Views)
