Using Keithley 2400 with labview program to measure 4-wire resistance
I just did. Im trying to run some of the examples but they won´t work
Message 11 of 13
(4,351 Views)
Just exactly how do they not work? You should be getting some error code when something does not work. What is the code? What is the function/VI you are trying to run? What type of connection do you have to the instrument (serial, GPIB, etc.)?
Message 12 of 13
(4,346 Views)
Thank you Albert-This was a huge help for this LabView rookie...
-Fred S.
Message 13 of 13
(3,696 Views)
