Using Watlow F4 Drivers
Did you try enabling the Guaranteed Soak ?
Message 11 of 13
(1,580 Views)
Yes and in testing it seems to have pretty much solved the problem. With guaranteed soak enabled, it does wait until it is within 1 degree before starting the soak timer. This will be plenty good for me. However, I'm just still confused as to why when I look at the settings for the soak step(on the actual watlow unit) it still shows that it is not actually setup to wait for Analog Input 1. Do you know why this is?
Anyways, regardless of that, you have solved my issue. Thanks so much for the help!
Message 12 of 13
(1,576 Views)
To really understand it, you'll probably need to dig into the modbus section of the F4 manual.
Message 13 of 13
(1,574 Views)
