Using a standard vi in labview 2011 to print to a wireless printer?
Is there any way using labview 2011 vi's to print a barcode to a wireless printer?
(3,414 Views)
Accepted by DanHoss
Hi Dan,
I found the following example for printing a barcode from any available printer, which looks like it's pretty close to what you want. The example was developed in LabVIEW 8.5, but it should work for 2011. I hope this helps!
David S.
(3,394 Views)
Thanks this vi works great for my needs.  I appreciate the help.
(3,387 Views)
