VISA: Error -1073807252 (Hex 0xBFFF006C)
Hi nehap,
May I ask what you changed the buffer size to?  How did you implement a delay to the input?  A little more context may help with troubleshooting your issue.
You also may want to try making a new forum post and reference this one.  Older posts generally have less visibility, and thus will not get as much attention.  Also this one already has a marked solution.  People may not think to check the page, considering there is a solution.  Additionally, you won't be able to mark a solution of your own once you find the answer.
Trevor H.
Technical Support Engineer
Message 11 of 14
(3,963 Views)
Hi Trevor,
Thanks for the reply. Could u please suggest the forum where I can put up this question?
I tried posting it in other groups, but I did not receive any response.
About the error part, I found out that when I include too many function blocks in my while loop the loop runs very slow and the complete program runs slower and I get that error. I have attached the picture of my VI. I tried putting a while loop on serial communication part but it doesnt help my program as i need continuos inputs to the PID block.
Message 12 of 14
(3,955 Views)
So to be clear, you are using a cRIO to communicate read serial data?  Are there other tasks the code should accomplish?  If so, what?
Having lots of code inside a while loop will slow the loop down, as the loop will not reset until all code inside it is executed.  We do however have a design pattern called producer/consumer which allows for parallelization of tasks, increasing efficiency.  This may be a useful solution to your problem of continuous input.  There is a white paper describing this design pattern, and how to use it.
Trevor H.
Message 13 of 14
(3,920 Views)
Thanks! this seemed to work for me. Just trying to read a simple string from an arduino via a TTL to USB converter.
I doubled the default value of the buffer, both devices @ 9600.
Message 14 of 14
(3,352 Views)
