VISA or Code Library Missing/Error -1073807202 occurred at Property Node (arg 1)
Yes, I am still getting the same error in every instance. The error dialog is "(Hex 0xBFFF009E) VISA or a code library required by VISA could not be located or loaded." Today I even uninstalled all NI products from my machine and reinstalled, I am getting an identical error.
Message 11 of 16
(2,495 Views)
What operating system are you using? Version of LabVIEW is 2015 64-bit?
Message 12 of 16
(2,485 Views)
I am using Windows 10 Pro - 64 bit and the LabVIEW is 2015 64 bit also
Message 13 of 16
(2,481 Views)
Sorry, I missed that short sentence in your first post when you said you have Windows 10. Windows 10 is not compatible with NI-Serial driver. Windows 8.1 and Windows 7 are OK.
I dug around looking for NI-Serial driver that is compatible with Windows 10, but none of them are. Do you have another machine you could try this on?
Message 14 of 16
(2,475 Views)
Accepted by ztg5025
I did try this already on another Windows 10 machine and it worked except for a read timeout, but I didn't realize that machine was running LabVIEW 2015 32-bit. I spoke with a former professor and he said that the drivers don't work well with the 64-bit version of LabVIEW. I reinstalled the 32-bit version on my own machine and no longer get the same error.
I do however, get a timeout on the serial read as I did on the other machine, but I suppose that's for another post.
Thank you AvatarAang for all of your assistance, I appreciate your time.
Message 15 of 16
(2,469 Views)
Hey, ztg5025.
No problem, happy to help.
Just a word of warning about compatibility. If Windows 10 is not included in the readme as a compatible OS, that means the driver has not been tested on it and unexpected behavior may occur. I just mean that you may get it working for the most part, but weird things could still happen. Good luck!
Message 16 of 16
(2,460 Views)
