11-22-2007 01:04 PM
11-22-2007 09:45 PM
11-23-2007 04:29 AM
thank you very much, it worked.
another problem i have is that there are vi's in the olxxx2 that requires "OLXXX2 Olympus Command.vi" however i can not find it in the olxxx2 pack i downloaded from here.
where can i find it?
11-23-2007 08:36 AM
11-25-2007 08:54 AM
Thank you again!
I
11-25-2007 08:54 AM
Thank you again!
I have
11-25-2007 08:54 AM
Thank you again!
I have another
11-25-2007
09:18 AM
- last edited on
10-01-2026
05:12 PM
by
Content Cleaner
Thank you again!
I have another problem though: In the Olympus Command.vi I Sometimes get from the visa read's read buffer 1x which ends in an error (and doesnt do anything).
it happends in the Select Filter Wheel.vi, OLXXX2 Configure Jog.vi, however it doesn't happen in the configure lamp.vi
here are the drivers [broken link removed]
11-26-2007 09:46 AM
11-27-2007 06:24 AM
Thank you very much on all of your help.
So far we manage to overcome all the issues we had.![]()
Apparently the last problem was a definition problem.
Thank you again,
Cheers,
Yoli
