VISA read problem
hi,
i am using labview 8.2.1 and trying to send commands to my microscope, olympus ix81.
im using the drivers i downloaded from NI.
i noticed that i can't preform a certain visa read, attached as Ol_control.vi
however i can preform other visa reads to the microscope and see them working in the microscope. for example - SET OBJECTIVE.vi
can someone look at these vi's and tell me what it the diffrence? and why can't i preform the action in ol_control.vi ?
Message 1 of 11
(7,035 Views)
In OI_Control, the command is terminated with just a CR and in Set Objective, the command is terminated with a CR and LF. This is the same solution in the other thread you posted to.
Message 2 of 11
(7,023 Views)
thank you very much, it worked.
another problem i have is that there are vi's in the olxxx2 that requires "OLXXX2 Olympus Command.vi" however i can not find it in the olxxx2 pack i downloaded from here.
where can i find it?
Message 3 of 11
(7,014 Views)
In _olxxx2.llb that was part of the zip file you downloaded.
Message 4 of 11
(7,004 Views)
Thank you again!
I
Message 5 of 11
(6,975 Views)
Thank you again!
I have
Message 6 of 11
(6,974 Views)
Thank you again!
I have another
Message 7 of 11
(6,973 Views)
Thank you again!
I have another problem though: In the Olympus Command.vi I Sometimes get from the visa read's read buffer 1x which ends in an error (and doesnt do anything).
it happends in the Select Filter Wheel.vi, OLXXX2 Configure Jog.vi, however it doesn't happen in the configure lamp.vi
here are the drivers [broken link removed]
Message 8 of 11
(6,967 Views)
Hello Yoli,
    I took a look at the driver, but did not see any differences in particular that would be obviously problematic.  Could you please provide more information as to the conditions that are present when the error occurs, and also please elaborate on "Sometimes"?  Ideally, you could reduce the code down to the bare minimum that reproduces the error everytime.  To go a step further, you can use highlight execution and/orr breakpoints to find out exactly which command is generating the errors.  After doing that, you have the power to look at the programming manual for your device and see if the driver is incorrect.  If it is, you can make the necessary changes and let us know, so that we can also change the driver.
    Something that is worth doing before all of that investigation, is upgrading the devices firmware.  Please let us know how it goes.
Cheers,
NathanT
Message 9 of 11
(6,936 Views)
Thank you very much on all of your help.
So far we manage to overcome all the issues we had.Smiley Very Happy
Apparently the last problem was a definition problem.
Thank you again,
Cheers,
Yoli
Message 10 of 11
(6,911 Views)
