VISA session duplicates every time I run the VI.
The visa session duplicates everytime I try to run the VI. I checked every possiblity to diagnose the error but I could'nt.
Please refer the attached image for clarity.
Has anybody faced the same problem.
What could be problem and the way to solve it.
TIA
Aswin
(4,145 Views)
Are you closing your resource via VISA Close?  That is the only time I have seen that.
(4,119 Views)
Yes I do use a VISA Close.
But to explain my program better, it is framed under event case nested in whileloop. So I have two boolean functions to open and close the visa session. (i.e, boolean 'connect' to open VISA and boolean 'Disconnect' to close VISA. Refer the attachment). Here when I open and close the visa the duplicate session does not appear.
This error happens if I don't close the VISA and instead press 'Abort execution' button followed by 'Run'.
I hope my explanation is understandable. Kindly lemme know if not.
Thanks for your time again.
(4,108 Views)
And there is your problem.  Abort Execution does not close any open references you might have (DAQmx, File, VISA, etc).  The Abort Execution should only be used while debugging and something goes horribly wrong.  You need to allow the VI to end (stop button, Panel Close event, etc) and close out these references as part of the shutdown.
(4,104 Views)
Accepted by Aswin.P
While you are debugging VISA Drivers you can go to "Tools>>Options" and hit this checkbox.
Don't leave it on- You'll develop some really nasty habits.
(4,091 Views)
Cool. Your solution seems to solve my problem.
Thanks for your time.
Cheers.
(4,080 Views)
Cheers.
Please, do not leave that checkbox checked after you have debugged your driver.  (Trust me on that OK?)  or, start another thread to discuss why it is a really bad idea to check that checkbox and leave it checked.
(4,069 Views)
