Where do I find the tektronix tktdsxxx library for the tktds7xx drivers.
I was sort of geting started with labview, and I am a bit new to it still. I think I got a fair understanding of things. But when I went out to actually download a driver for one of my instruments I got the driver for the tktds7xx, but it states it needs this tktdsxxx library also. I have been unable to find it so far. Anyone know were it is? Where are the generic tektronix drivers in general because I have other ones I want to use as well like 6xx 2xx etc.?
(3,664 Views)
There should have been a separate folder called _Shared created when you unzipped the driver.
(3,663 Views)
I got the driver from the "find instrument drivers-Search results" menu then it automatically downloaded it. I can't find a "_Shared" folder anywere would it be in the same directory or someplace else? I was trying to find one on Tektronix web sight not much luck finding one there yet.
(3,660 Views)
Ok so what I figured out was that they didn't put the tktdsxxx file into the Labview 8.0 download. I went back to the Labview 7.0 download and it was in that one I suppose it shouldn't matter for this file.
(3,653 Views)
Glad you found it. I haven't upgraded to 8.0 yet so I haven't had a chance to try any of the 8.0 driver downloads. The tek drivers have always been a little wierd with the separate _Shared folder required. You might want to add this feedback on the driver download page.
(3,649 Views)
The tktds7xx driver has been updated it has the shared library in the zip file.
(3,617 Views)
