Which GPIB-USB Interface to Buy?
Other than for the great support on this forum (!), why should I buy a GPIB-USB-B instead of an Agilent 82357A? My application is general-purpose lab use.
Steve
(3,324 Views)
The GPIB-USB-B supports both NI-488.2 and NI-VISA APIs. The Agilent 82357A only supports the VISA API. National Instruments has done quite a bit of work to ensure that the GPIB-USB-B driver maintains backwards compatibility with previous NI-488.2 interface drivers. We have also done extensive testing with LabVIEW. With the GPIB-USB-B, you'll have the luxury of selecting from a wide range of programming environments and APIs.
Craig A.
National Instruments Engineer
(3,324 Views)
Craig,
Thanks for the response. It appears that your product is the best choice.
Steve
(3,324 Views)
