communicate with a USB port, DLL in Visual Basic, program in LabVIEW
Hello !
I have to write a program in LabVIEW (I'm a novice in this language) to communicate with an interferometer via an USB port. The drivers and DLL for the USB port are written in Visual Basic.
-I don't know if it's possible to use them just so, or if I need to adapt them to LabVIEW.
-And how to do to call a particular function of my DLL ?
Thank you for your answer...
Gaelle
(6,054 Views)
You use the Call Library Node function in LabVIEW to access a DLL. Specifics on how to select the DLL and the functions can be found in the shipping document called "Using External Code in LabVIEW". Go to Help>Search the LabVIEW Bookshelf.
(6,048 Views)
Thank you very much. Actually, I had just found the function but now I even got the confirmation it's the good one.
Unfortunatelly, I can't access the pdf document "Using External Code in LabVIEW". Have you got a copy ?
(6,042 Views)
Download it here.
(6,038 Views)
Thank you again...
I've got a new problem. When I enter the name of my function (Call library function\Configure\Function Name), LabVIEW send me an error message and close. Maybe it doesn't reconize the function of my dll...
May I use "create .c file" (right click on the Call Library Function Node) to copy the code of my dll in a new file?
(6,021 Views)
That's not what "Create .c file" will do. It will create a new .c file for you to use as a template in creating a new .dll.
(5,996 Views)
Nakaose,
You should refer to these links:
Tutorial: Sharing code with VB:
==>  http://zone.ni.com/devzone/devzoneweb.nsf/Opendoc?openagent&5F9B8F1FF859549186256E5C0005457D
Tutorial: Can LabVIEW C?:
==> http://zone.ni.com/devzone/devzoneweb.nsf/Opendoc?openagent&FD4B480C24A159BD86256E60005B0120
JPR
NIF
(5,975 Views)
