hello JoshuaP,
DIN-Meßbus is a protocoll like CAN or Profibus... but it wasn`t offten used in industry, so nobody really has information about this protocol.
the device is connected by a pci-485 (rs-485) card. the rs 485 is only the hardware-connect-protocol, wich supplies the device with demanded voltage levels...
the data-protocoll is a DIN-Meßbus protocoll. this protocoll is partioned in a view levels (layer 1,2 -for standard telegrams, layer 3 -is the userinterface telgram). if you want to see the complete construction of a DIN-Meßbus protocol, please go to: www.measurement-bus.de
What i need is a softwaredevice (for example a labview dll) wich contains this protocol, so i can implement this one or a windows based driver, wich works between labvie
w and the PCI-485 card...
thanx and a nice weekend
xtocox
Dr. S. Twieg
