doesn't generate COM port in MAX for USB interfacing
hello there,
 i am connecting tektronix scope TDS7104 via FT232R USB UART connector and  connection is established successfully. i am connecting usb socket at COM3 port of CPU. problem is that in MAX, it displays" USB RAW" connection as VISA resource name instead of "COM3". and writing manually "COM3" as VISA resource name it geneartes error after passing execution from VISA write block.. give possible solution guyz...
(3,844 Views)
Did you install the driver for FTDI chip?
(3,829 Views)
yes i have installed FT232R USB UART driver and computer as well as MAX detects the interface. but in GUI front panel, it fails to update resource name. i am sure the USB end of this connector i connect, is COM3. earlier using the same connector, FP generated COM3 as resource name and read  data successfully from instrument
(3,820 Views)
Are you on a windows operating system?
I would check in the device manager and make sure Com3 is assigned to your FTDI adapter. Sometimes Windows assigns a different Com port designator to these adapters each time you plug them in.
Now Using LabVIEW 2019SP1 and TestStand 2019
(3,808 Views)
i have tried all ports but it results nothing and troubleshooting since 2 weeks...still success not achieved
(3,792 Views)
