error:-1074130544 after calling TDS 3034B via Ivi_WriteInstrData and Ivi_ReadInstrData
I wrote a DLL in C++ to get direct access in a testprogramming language called CAPL. CAPL is part of Vector's CANoe sw.
I can send as many write commands as i want like:
"Status = tkds30xx_WriteInstrData (session, "BEL");"
that is working fine an sets the Status always to 0.
but as soon as I query sth. like "SET?" for example:
"Status = tkds30xx_WriteInstrData (session, "SET?");"
and read it back with:
"Status = tkds30xx_ReadInstrData (session, 5000, InstruData, &BuffLenout);"
that works just once. Till here it sets status always to 0.
NOW if I try another WriteInstrData command.. like "SET?" oder "BEL"
Status is set to -1074130544 and IVI driver prevents the command from being sent.
Why is my session invalid here?
Find attached NI-SPY capture...
Florian
(4,199 Views)
I did not see any error capture data from your spy-log file.
I suggest you to download the NI-Certified driver here:tds3034B
(4,160 Views)
Hi, that is the one I'm already using..
From my point of view the tkds30xx_ReadInstrData command (that is pointing to Ivi_ReadInstrData) does not close the function and leaves the driver in read mode where it doesn't accept any new instuctions..
To avoid that, I want to use the "viqueryf" command from the visa.h. The command is already used by the
tkds30xx_init function as you can see in the NI-spy file. That viqueryf sends and reads back a query formated so it closes the read stream in the driver. My issue is now that the viqueryf command is used by functions like "tkds30xx_init" but it is not available as command or function in the tkds30xx.h. tkds30xx_init function calls it from the lib file linked in my IDE.
How can I call that function?
(4,149 Views)
Accepted by Flori-Conti
Hi, as to the viQueryf function, you need to include the visa.h file.
Which IDE are u using?
(4,147 Views)
