fluke 6100A driver error
I have a quesiton on the fluke 6100A driver.  The first time I run my program, the initialization of the driver will give me an error, but if I run the program again, the error will go away.  Why is that?
yik
Kudos and Accepted as Solution are welcome!
(4,583 Views)
Pretty important to provide the error code/message if you want some help.
(4,581 Views)
Hello yik,
      The Instrument Driver Troubleshooting Guide is a great resource.
Cheers,
NathanT
(4,543 Views)
I hope you guys are still with me.  THe error that I get once in a while is
VISA:  (Hex 0xBFFF000E) The given session or object reference is invalid.
-1073807346
It seems like this is happening at the initialize.vi whent it is trying to open a visa session.  This error is usually gone when I rerun the program, but I want to fix this, since this makes my problem unreliable.
Yik
(4,347 Views)
Accepted by jyang72211
Hi Yik,
The details of this error can be found at the knowledgebase article below.
http://digital.ni.com/public.nsf/allkb/A2561CDE98B66DD4862566510078264F?OpenDocument
Raj
(4,321 Views)
Thanks.  This could be a solution, let me test it.
(4,289 Views)
