i have a national instrument GPIB card (ni 488-2) but i can t find the good driver for Windows 2000,where can i find it
In fact i download the new version for install this card but this program don t modify the driver
(3,453 Views)
There is a great online resource that will help you install the correct driver for Windows 2000, as well as walk you through installing the GPIB card. You can find this resource at:
http://www.ni.com/support/gpib/
From this page, just select your operating system and board, and instructions specific to your setup will be generated. It is important to note that you need to uninstall any older GPIB drivers (NI-488.2) before you install the new driver. Version 1.60 or later is required for a Windows 2000 machine.
(3,453 Views)
And, it is good practise to remove your GPIB Card before Installing the new driver. Install the card again upon completion of driver installation.
Try GPIB-USB-B, if you upgrading your card.
Cheers!
Ian F
Since LabVIEW 5.1... 7.1.1... 2009, 2010, 2014
依恩与LabVIEW
LVVILIB.blogspot.com
(3,453 Views)
