ini string to DAQMX physical channel
I would like to save all my DAQMX physical channels as strings in a ini file.  My program will read the information as string and convert them to DAQMX physical channel.  Is doing a type cast the only way to convert a string into a DAQMX channel type?  I wanted to say all my communicaiton information in a ini in case something change.  Thanks!
Kudos and Accepted as Solution are welcome!
(3,801 Views)
Accepted by jyang72211
No typecast. You can wire a string directly to the channel input.
(3,799 Views)
ahhh, good!  Thanks!
(3,794 Views)
