is HP-IB E2078A/82350A (PCI) usable instead HP-IB82341-ISAcard
in trubleshooting at an old spectrometer-device  I found a PC-System with  NT4.0,
using an ISA-GPIB-card:  HP-IB 82341. - and the spectrometer works  fine.
Now I have a new PC-System with only PCI-slots and an HP-IB-card E2078 / 82350  (PCI).
The new HP-IB-card  ( PCI ) is not able to communicate with the spectrometer-HP-IB-interface.
My question: is it in principle possible to  communicate using a PCI-E2078/82350A - card
instead of  the old ISA-HP-IB-board  HP-IB 82341 ?
Thx for information,
Hartmut Winkler
Prod-IT / LAN
Multek Germany
Email hartmut.winkler@de.multek.com
(5,317 Views)
In principle, it doesn't matter whether the GPIB controller card is ISA or PCI.
In your specific case, the E2078 is made by Agilent, not National Instruments, which is where you are. Also, a quick check on the Agilent web site for that card showed that was made for HP-UX workstations. Are you trying to use this on a Windows machine? I don't know if there was anything hardware-specific that made it for HP-UX or whether they simply provided different software with it. You will probably have better luck contacting Agilent. Yoy may want to try the Agilent I/O libraries as this is their equivalent to the MAX software that NI makes. This installs a VISA layer and allows you to communicate and troubleshoot connection problems.
(5,306 Views)
