libnipalu.so failed - Scientific Linux
I have installed LabVIEW 2013 for Linux on a Scintific Linux machine, version 6.4 . Both VISA and DAQmx Base (version 3.7) was also installed without any problems. But when I try to run lsdaq to recognise a NI device (USB-6009) I get this error message:
Detecting National Instruments DAQ Devices
Found the following DAQ Devices:
libnipalu.so failed to initialize
Perhaps you need to run updateNIDrivers
/usr/local/bin/lsdaq: line 7:  2367 Aborted                 /etc/natinst/nidaqmxbase/bin/daqmxbase_listdevices
I have tried updateNIDrivers, also running without any problems, and drivers were upgraded. But the same thing happens when I run lsdaq. What can I do to solve this?
Regards
Per Jørgensen
(4,229 Views)
(4,094 Views)
