looking for information on a gpib-rs232 part no: 191971C-01L
HELLO,
I have an same problem when configuration, The message is "There was an error locating  the GPIB-rs232/485/422". I tried many times and check everthing but failed. i do wish someone can give me instructions?  The product is also made in Hungary, p/n 191971c-01L.
DING jianguo
dingjg@sinap.ac.cn
Message 11 of 16
(2,079 Views)
Hi DING,
Have you read through the history of this forum post? Are you using a null modem cable? The hardware line, (CTS/RTS) are needed in order to run the configuration program properly.
Matt
Matt
Message 12 of 16
(2,058 Views)
We did find one issue where the GPIB-RS232 would not be detected if the computer connecting to the GPIB-RS232 had Remote VISA resources enabled when searching for resources.
A work around is to disable finding resources on remote systems. To do this open Measurement and Automation Explorer and navigate to Tools»NI-VISA»VISA Options»Remote. Under Enable finding resources on these remote systems, uncheck all the resources. Click on Save.
This should allow the wizard to detect the GPIB-RS232.
Steven T
Message 13 of 16
(2,045 Views)
Should it work with a USB RS232 converter? I get the same error and have the settings the way you suggested and am using a null modem cable.
Message 14 of 16
(913 Views)
it should work the same?
How are you configuring it?
Message 15 of 16
(896 Views)
9600,8, none, 1,  hadrware
Thats what the book said the default was for the GPIB-RS232.
I was able to get it to work by using an old XP laptop with a built in RS232 port.
Message 16 of 16
(893 Views)
