need drivers for GPIB cards that works on MSDOS
I need the drivers for the AT-GPIB/TNT and AT-GPIB cards, the support section of them displays a message that it has been archived and the link to download them is broken, the reason I need them is because I have a in line tester machine that uses it, it runs on a Compaq deskpro 386, the equip is owned by the client so I can't change to a newer model or something like that, I have tried to restoring all GPIB files including the gpib.com from 2 backups but it won’t work it just freezes after the message that the driver has been installed like on the image I've attached (I’m sorry for the quality my phone camera is scratched). After that image the pointer just keeps flashing under it and nothing happens so I thought re installing the software could work but I don't have it since the equip is not mine an really old. so if you could help me either fix it or get the drivers i would be grateful, o and also I tried with a AT-GPIB/TNT that I had on another equip but the 386 is not plug & play ready so I ended up in the same place with it and i don't have that driver because the other equip ran in windows NT so is not the same.
(3,664 Views)
Accepted by matu-t
Poke around these directories, you may get lucky (or not):
ftp://ftp.ni.com/support/gpib/doswin3/
-AK2DM
(3,662 Views)
I think maybe the proxy was bloking the page either way I have alredy got the drivers thank you.
(3,660 Views)
