problem in IviSpecAn - Acquire Y Trace.vi example
Hi
I opened IviSpecAn - Acquire Y Trace.vi example from C:\Program Files\National Instruments\LabVIEW 2011\examples\instr. Then I opened Measurement & Automation Explorer (MAX) and configure my IVI logical name and then choose the correct IVI logical name from the drop down on the front panel of the IviSpecAn - Acquire Y Trace.vi.
My logical name is “Spectrum” and select “N9030A driver (agmxa)” from driver session. I choose simulation mode with “nisSpecAn”.
I run the IviSpecAn - Acquire Y Trace.vi example (after choosing the IVI Logical name), it generates the following error:
Error -1074135008 occurred at IviSpecAn IVI Error Converter.vi
Possible reason(s):
Primary Error: (Hex 0xBFFA0020) Unknown channel or repeated capability name.
Complete call chain:
     IviSpecAn Configure Trace Type.vi
Is there some problem in the driver or am I missing something? I'm new to LabView and to IVI, and I would really appreciate any help.
Thank you
 Yasamin Gharib
(4,109 Views)
Can you attach a screen shot of your fp settings?
(4,088 Views)
Hi
I used IviSpecAn - Acquire Y Trace.vi example from C:\Program Files\National Instruments\LabVIEW 2011\examples\instr without any change into configuration, setting or anything.
Only, I opened Measurement & Automation Explorer (MAX) and configure my IVI logical name and then choose the correct IVI logical name from the drop down on the front panel of the IviSpecAn - Acquire Y Trace.vi.
I attached images of MAX configuration.
I run the IviSpecAn - Acquire Y Trace.vi example (after choosing the IVI Logical name), simulator setup window opens but when I enter ‘ok’, it generates the following error:
Possible reason(s):
Thank you
 Yasamin Gharib
(4,077 Views)
Accepted by yasmain62
Did you try Trace1? TRACE1 in all CAPs is not a valid virtual name for the MXA models (see screen shot).
I ran the class driver example using Trace1 with no issues.
(4,059 Views)
Thanks, it is ok
(4,053 Views)
