02-11-2008 03:30 PM
02-13-2008 08:44 AM
02-13-2008 07:53 PM
Thanks Chris
I did have 1.7 installed originally and now I've updated to 2.2. Still get the same error message. I thought that since the HP5508A was pre-488.2, it would need to run an earlier than ver 2.2 of the 488 software. Does the 488.2 software only pertain to the NI PnP card?
I did try to install the complete VB program and run the debug. It stops when it's trying to read from the 5508A display unit. There is a blank value for what is returned. I know the peripheral equipment is working as I used another computer with the laser display I'm trying to make work, and it works fine.
I seem to be sensing a problem around the Gpib-32.dll. Probably because this seems to be a Gpib problem. I have tried swapping in another version of this dll only to get a Gpibmngr.dll error.
Anything else you can offer would be appreciated.
02-25-2008 07:07 PM
