Showing results forĀ
Search instead forĀ
Did you mean:Ā
read data from TDS 1002b using Labview with USB
thanks, unfortunately I was hoping for a static screen shot of the display so I could pick off the various data for the scope screen.
Regards
Ray Farmer
Message 21 of 51
(2,680 Views)
Would you please tell me how must I capture signal in scope and save for you?
Message 22 of 51
(2,676 Views)
just point and shoot your camera at the scope screen but not in video and try to keep it steady so that the picture is in focus. try use a fast shutter speed.
Regards
Ray Farmer
Message 23 of 51
(2,671 Views)
Thank you
I shot a picture with high quality
regards
Message 24 of 51
(2,667 Views)
please read capture using NI I/O trace
Message 25 of 51
(2,664 Views)
Dear Ray Farmer
Thank you for your helping.
I can run Tektronix TDS 200 1000 2000 Series Acquire Continuous Waveform.Vi.
It can properly work.
Thank you again.
Message 26 of 51
(2,618 Views)
Dear Naser1363
I am also struggling to acquire the datat from the TDS 2012c to Labview. I got a clear idea after opening the VI below you posted
Tektronix TDS 200 1000 2000 Series Acquire Continuous Waveform.vi 38 KB
I am wondering if the eight sub-VI's that go along are what you made your own or they can be found from somewhere
Is there anyway you can post the sub-VI's?
Thank you for your geat help
Message 27 of 51
(2,545 Views)
Help>Find Instrument Drivers. Login and follow the instructions.
Message 28 of 51
(2,543 Views)
I'm a Labview begginer and i downloaded the vi, also downloaded the instrument drivers. The program is running but i can't reading from the osciloscope... I have a TDS 1002 with GPIB-USB-HS... What i need to do?
Luis
Message 29 of 51
(2,412 Views)
You must select the correct VISA resource name. Did you select it from the pull down menu? Click on the control's arrow to see the menu.
Message 30 of 51
(2,410 Views)
